Eric Favre
COMSOL Employee
10 years ago
22 set 2014, 05:39 GMT-4
Hello Aaron,
perhaps you want to check out your conductivity, which is negative in your model, that explains why you get cooling instead of heating.
Moreover, in 2D axi, you need to multiply by 2*pi*r the weak contribution.
At last, 1e5 W is a large value. Perhaps you want to estimate your Marangoni number and your Reynolds number so that you have an estimate of the thickness of the boundary layers. Your mesh should be adjusted accordingly. You can guess as well the regime of the flow (laminar or turbulent).
I hope this helps, good luck,
Eric
Hello Aaron,
Eric
Eric Favre
COMSOL Employee
10 years ago
22 set 2014, 05:44 GMT-4
I forgot to add that the Microfluidics Module contains the physics needed to ease the equations part in the "Laminar Two-Phase Flow, Moving Mesh Interface". You can use it without the Moving Mesh of course. The Marangoni condition is expressed by entering the temperature dependent expression of the surface tension. You can add a Heat Transfer equation to get the full coupling.
10 years ago
22 set 2014, 05:57 GMT-4
Dear Eric,
Thank you for your reply.
I just found out abut the error in the conduction.
Also, thank you for solving the weak contribution problem.
With regards,
Aaron
Dear Eric,
With regards,
Aaron
10 years ago
20 nov 2014, 14:07 GMT-5
Hi Eric,
I am bit confused by your remark regarding negative conductivity. I plotted the value of "k" as defined in the program for the specified temperature range. I did not get any negative value.
Susant
Hi Eric,
Susant
Eric Favre
COMSOL Employee
10 years ago
15 dic 2014, 06:42 GMT-5
The file has been edited and corrected since the mention of the wrong conductivity.
Here the heating is pretty strong : the Marangoni number should be evaluated that will probably show that the regime gets turbulent, or at least time-dependent.
It's a good idea to use the time-dep. solver then, because the flow is very likely to be unstationnary.
The mesh shown in the model is not consistent with the boundary layers size, that you can estimate with your Marangoni number.
So the error in your model is a consequence of the divergence of the non-linear solver. rho is actually correctly defined.
I recommend strongly ramping up the heat source in time (with a smoothed step function), and avoid using a point heat source in space, since the temperature will be mesh dependent at this point. If you use the point heat source, have a look to the option to specify a radius for the heat source, it spreads over a small location the heat source, without adding extra dofs and keeping the problem well-posed (it adds directly the right contributions to the matrix system).
There is a nice tutorial about point heat sources in the Heat Transfer Module : localized Heat Source that you can find here :
www.comsol.fr/model/localized-heat-source-17307
(this example is new in COMSOL V5, it makes use of the special operators diskavg() or the like).
For fluid flow problems, reading the documentation of the models in COMSOL and trying not to introduce discontinuities in time or in space (that lead to shocks that are in some circumstances hard to damp out) is probably a good advice. Estimating the size of the boundary layers with a quick non dimensional analysis should be done at some point. This is hard to automate. You can read a nice similar analysis in terms of natural convection in :
www.comsol.fr/model/buoyancy-flow-in-free-fluids-665
I hope this helps,
Eric
COMSOL France
http://www.comsol.fr/model/buoyancy-flow-in-free-fluids-665
I hope this helps,
Eric
COMSOL France
