error while saving
Hi all,
I have a problem while saving project in comsol 3.4
Exception:
java.lang.OutOfMemoryError: Java heap space
(rethrown as com.femlab.util.FlFatalException)
Fatal error.
- Type: OutOfMemoryError
Does anybody know how to treat it?
Thankjs in advance,
Alex
1 Reply Last Post 19 apr 2010, 10:11 GMT-4
Posted: 2 decades ago 19 apr 2010, 10:11 GMT-4
I beleive its the "Java" section that does not have enough RAM, probably you have a complex model, try to either use the server - client mode (this doubles the RAM available for the Java) or check how to adapt the java heap in the installation guide, but I believe more to java is less for the solver, one have nothing free ;)
Hi I beleive its the "Java" section that does not have enough RAM, probably you have a complex model, try to either use the server - client mode (this doubles the RAM available for the Java) or check how to adapt the java heap in the installation guide, but I believe more to java is less for the solver, one have nothing free ;) Good luck Ivar
