Moving heat plate comes in contact with surface
Posted 30 set 2014, 10:32 GMT-4 Heat Transfer & Phase Change, Geometry, Mesh Version 4.3 1 Reply
Hi, I have a model using the Heat Transfer module and the Deformed Geometry module. I have a heating plate at a fixed temperature and a long sheet initially at ambient temperature. Both entities are initially separated. The plate moves at a constant speed and comes in contact with the sheet. According to the geometry of my model and the trajectory of the heating plate, both entities should come in contact (they should just brush against each other).
When solving the model, even tough the plate clearly comes in contact with the sheet, it doesn't heat it.
What should I do so the plate heat the sheet as it moves along?
Thank you.
Thank you.
1 Reply Last Post 1 ott 2014, 08:13 GMT-4
