Exporting a geometry file (parasolid_binary) using MATLAB Livelink
I would like to export a geometry from COMSOL in parasolid_binary using MATLAB live link ?
You can easily do this from COMSOL desktop, however, I could not do it using the Live link.
Please, provide me the syntax
Thank you in advance
5 Replies Last Post 28 ott 2016, 03:36 GMT-4
Hello Mohamed Zanaty
Posted: 1 decade ago 11 nov 2014, 23:34 GMT-5
Hello ,I need too, Could you find this solution? Pleas tell me
Hello ,I need too, Could you find this solution? Pleas tell me Thanks [QUOTE] Hello, I would like to export a geometry from COMSOL in parasolid_binary using MATLAB live link ? You can easily do this from COMSOL desktop, however, I could not do it using the Live link. Please, provide me the syntax Thank you in advance [/QUOTE]
Posted: 1 decade ago 12 nov 2014, 03:10 GMT-5
yes, you can export your geometry using MATLAB livelink through the following syntax:
model.geom('geom1').export('geomfile.x_b')
BR
Mohamed
yes, you can export your geometry using MATLAB livelink through the following syntax: model.geom('geom1').export('geomfile.x_b') BR Mohamed
Posted: 9 years ago 20 ott 2016, 10:40 GMT-4
It does not work on COMSOL 5.1 and MATLAB 2013. Any other suggestions?
Gaetano
It does not work on COMSOL 5.1 and MATLAB 2013. Any other suggestions? Gaetano
Posted: 8 years ago 20 ott 2016, 15:36 GMT-4
Reading and writing of Parasolid files requires the CAD Import Module, the Design Module or the LiveLink for CAD products (See www.comsol.com/products/specifications/cad/). Your license may not include these products. You can check which products are included on your license by going to File>Licensed and Used Products.
Reading and writing of Parasolid files requires the CAD Import Module, the Design Module or the LiveLink for CAD products (See https://www.comsol.com/products/specifications/cad/). Your license may not include these products. You can check which products are included on your license by going to File>Licensed and Used Products. Best regards, Jeff
Posted: 8 years ago 28 ott 2016, 03:36 GMT-4
Hey Jeff,
Thank you for your suggestion. But University license has that package.
I have fixed the problem. It was directory problem. Comsol script helps me a lot.
Best Regards
Gaetano Formato
Hey Jeff, Thank you for your suggestion. But University license has that package. I have fixed the problem. It was directory problem. Comsol script helps me a lot. Best Regards Gaetano Formato
