Force between a parallel plate capacitor
Posted 23 apr 2010, 15:12 GMT-4 2 Replies
I am very new to comsol. that being said, I have managed to model my problem in 3D, mesh it and view the results.
I am attempting to measure the electrostatic force between an AFM tip and a grounded sample. Before I do this I want to verify that my method corresponds with the theoretical result. To this end, I have modelled a parallel plate capacitor (a flat box with appropriate boundary conditions). The box is 1e-3 x 1e-3 x 1e-6 [m] with the top surface set to 1 [v] and the bottom surface grounded.
I would like to calculate the force one plate exerts on an other. Theoretically, the result should be:
F=V^2*permittivity*Area / ( 2*separation^2)
How would one set up post processing to obtain this solution?
I was thinking that the total charge on a place could be found by a surface integral of D.ds, but this would give you a Force field - not a total Force.
Thanks, all help would be much appreciated,
E
E
2 Replies Last Post 7 mag 2010, 01:17 GMT-4
