Laminar Counter-flow in Concentric Pipes
Hello. I'm relatively new to COMSOL and I've been trying to model a simple counter-flow through concentric double-pipes. Currently, I have the model in a 2-D axisymmetric configuration and three domains: fluid, wall, fluid. I have water in both pipes and copper as the pipe wall. The outer pipe is flowing at a higher temperature than the inner pipe, and both are using water just to keep things simple. The outer pipe is supplied a constant temperature on it's surface.
I just learned that there is a new feature since version 4.3 where a domain is no longer needed to be created to define a thing wall. However, let's say I want to keep the wall. How would I handle the wall? Would I have to select another physics (Heat Transfer in Solids) along with Heat Transfer in Fluids? What options of boundary conditions can I apply to the wall and which physics?
Thank you. I appreciate your help.
6 Replies Last Post 17 dic 2014, 15:28 GMT-5
Posted: 10 years ago 17 dic 2014, 08:33 GMT-5
Hello Van,
If your license includes either the CFD Module or the Heat Transfer Module (or both), there is a physics interface for Conjugate Heat Transfer that greatly simplifies setting up this sort of analyses - See screenshot and also www.comsol.com/products/specifications/heat-transfer/.
Hello Van, If your license includes either the CFD Module or the Heat Transfer Module (or both), there is a physics interface for Conjugate Heat Transfer that greatly simplifies setting up this sort of analyses - See screenshot and also http://www.comsol.com/products/specifications/heat-transfer/. Best regards, Jeff
Posted: 10 years ago 17 dic 2014, 13:19 GMT-5
Thanks for your response, Jeff. Unfortunately, my university only has the Heat Transfer in Solids and Heat Transfer in Fluids modules. Is there a way to simulate this program with those two modules?
Posted: 10 years ago 17 dic 2014, 13:57 GMT-5
Hello Van,
There are no modules by those names.
To determine what modules the license includes, go to the File>Licensed and Used Products window (in recent versions) or Options>Licenses (in older versions).
Hello Van, There are no modules by those names. To determine what modules the license includes, go to the File>Licensed and Used Products window (in recent versions) or Options>Licenses (in older versions). Best, Jeff
Posted: 10 years ago 17 dic 2014, 14:14 GMT-5
Oops. I didn't mean modules; I meant physics. The university has the COMSOL Multiphysics with only Heat Transfer in Solids and Heat Transfer in Fluids physics.
Posted: 10 years ago 17 dic 2014, 15:20 GMT-5
OK, it sounds like your license does not currently include either of the CFD Module or Heat Transfer Module, which means you will have to couple the physics "by hand".
Posted: 10 years ago 17 dic 2014, 15:28 GMT-5
How would I couple a fluid and the wall? Is it a boundary condition under Heat Transfer in Fluids?
