Average over a 3D rectangle.
I computed some field over 3D. I want an average of the magnitude of that field over a rectangular region. I can see how to make a cut line segment and average over that line segment, but I don't see how to make a cut plane segment for averaging over a specified rectangle. Am I stuck using a full cut plane and doing a ratio of integrations with logical conditions to define the rectangular region mathematically? Or is there some way in post-processing with a few clicks to average over a rectangle that wasn't already a surface pre-defined in the geometry?
2 Replies Last Post 2 gen 2015, 02:16 GMT-5
Posted: 1 decade ago 31 dic 2014, 15:46 GMT-5
BTW, I also _do_ know that I can create some geometry region, "Update Solution," and use a "Surface" data set based on that region. It's just that in my case "Update solution" takes quite a while, so I was wondering if there was a way to define simple regions for averaging in post processing.
Posted: 1 decade ago 2 gen 2015, 02:16 GMT-5
There two approaches are the simplest ways to do achieve what you want.
[QUOTE]Am I stuck using a full cut plane and doing a ratio of integrations with logical conditions to define the rectangular region mathematically?[/QUOTE] [QUOTE]BTW, I also _do_ know that I can create some geometry region, "Update Solution," and use a "Surface" data set based on that region.[/QUOTE] There two approaches are the simplest ways to do achieve what you want.
