Nagi Elabbasi
Facebook Reality Labs
9 gen 2015, 23:18 GMT-5
Hi Zheyu,
Yes you can apply a force proportional to the contact gap in COMSOL. This is one way of modeling electrostatic forces, surface tension forces, and adhesive contact. You can use the contact gap in the load definition. For example pressure = C * gap_p1 * (gap_p1 > 0.0) will apply a normal pressure equal to C times the gap only if the gap is positive. COMSOL will take care of updating the gap calculation with deformation. You may need to increase the “Manual control of search distance” contact pair setting so that the gap is more likely to be defined when the surfaces are not in contact. That is because in “standard” contact you don’t really need the value of a big positive gap.
Nagi Elabbasi
Veryst Engineering
Hi Zheyu,
Nagi Elabbasi
Veryst Engineering
10 gen 2015, 05:15 GMT-5
Dear Dr. Nagi Elabbasi,
Thank you very much for your detailed reply. The way you posted is exactly the one I wanted to use. However, I don't know how to define the gap_p1 as it varys on the force-applied surface in a cylinder-plane contact model.The model I want to simulate is the JKR model (Johnson, K. L., Kendall, K., & Roberts, A. D. (1971). Surface energy and the contact of elastic solids. Proceedings of the royal society of London. A. mathematical and physical sciences, 324(1558), 301-313.). If I could perfectly define the contact gap, it will be easier to achieve the goal. Besides, I have no idea what the “Manual control of search distance” stands for. Would I ask your further explanation? I really appreciate your great reply.
Best regards.
Zheyu Liu
Best regards.
Zheyu Liu
Nagi Elabbasi
12 gen 2015, 08:52 GMT-5
You're welcome Zheyu,
The gap is automatically defined by COMSOL when you define and use a contact pair. The variable name will not be exactly as above but you can find it from the list of post-processing variables. Also the “Manual control of search distance” is in the contact pair definition settings.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
