Post-processing of mph files with script or matlab
Posted 19 mag 2010, 05:08 GMT-4 0 Replies
It is likely a trivial question but I could not sort out the answer by myself.
Position of the problem:
I am solving a 2-dim time-dependent PDE model, with dependent variables u(x,y,t), v(x,y,t),k(x,y,t),p(x,y,t).
Since simulations need to run over long times, I produced a set of .mph files: the first one
saves the state of the model from t = 0 to t = T1, the second one starts from T1 to t = T2 and so forth,...
Out of all the data produced I need to make statistical analysis on the variables u,v,k,p just at few spatial locations.
I am running version 3.5 (NOT 3.5a), hence I may use comsol script. On the other hand, have not access to
Matlab easily (I could arrange it, if necessary, but would rather not).
In conclusion, I would like to write a script that
a) load sequentially the .mph files
b) for each simulation extracts the arrays u,v,k,p at the locations selected and assembles them into one single array
c) makes the postprocessing. This seems the easy part.
However, up to now, I only used COMSOL through its graphical interface, so am quite unexperienced
with scripting.
I anticipated that it looks like trivial, but from reading the user's guide, I was not able to understand
how doing point (a).
Thanks for your cooperation
Fabio
Hello Fabio Sattin
