RF Module, Direction of the global incident field
Posted 20 mag 2010, 15:13 GMT-4 2 Replies
I'm trying to modelise the scattered field in 2D around a round metal cylinder (wich is a circle in the 2D model). The idea is to see the scattered field around the metal cylinder produced by a 600 MHz incident wave. The metal circle is inside a rectangular wich is Air, and the whole thing is surrounded by a PML. The problem is that the result obtained is reversed from what I expected. The scattered field look like the incident wave is travelling from right toward left, but as I understand it, by default the incident wave is going from left to right.
How can I verify the direction of the incident wave?
Also, either in Scattered mode or Non-scattered mode, how can I turn off the global wave excitation if I want to use an excitation on a boundary for example?
I read the RF User's guide and RF Model Library, and the explanation of how to set up the excitation is not very detailed. So if anyone can help, it would be very appreciated.
Jonathan
Jonathan
2 Replies Last Post 21 mag 2010, 16:58 GMT-4
