How to deal with parameters or variables having units with fractional or non-integer powers
​In simulation of reacting flow like reactors, there are parameters or variables like k, and -rA having units with fractional or non-integer powers, like
mol.bar^0.5 or
mol^0.3.s^-1.
Comsol throws warning and in defining other parameters based on them it raises errors.
One way is to make the whole problem dimensionless, but this is not an easy task in many cases. Moreover the predefined Comsol physics are not dimensionless.
I would appreciate if there is a way to resolve this issue.
Saeid
2 Replies Last Post 28 gen 2015, 08:03 GMT-5
Posted: 1 decade ago 27 gen 2015, 15:47 GMT-5
I have used following method:
r = 5.012e11[m^3/(kmol*s)]*exp(-24054[K]/T)*c_O2*((c_CH4[m^3/mol])^0.5)[mol/m^3]
In this only concentration, c_CH4, is converted to dimensioless and after power 0.5 it is turned back to concentration.
Best regards
Tero Hietanen
Hi, I have used following method: r = 5.012e11[m^3/(kmol*s)]*exp(-24054[K]/T)*c_O2*((c_CH4[m^3/mol])^0.5)[mol/m^3] In this only concentration, c_CH4, is converted to dimensioless and after power 0.5 it is turned back to concentration. Best regards Tero Hietanen
Posted: 1 decade ago 28 gen 2015, 08:03 GMT-5
Hi Tero,
Thank you for your response. It is a quite method. I will definitely try that.
Thanks again,
Saeid
Hi Tero, Thank you for your response. It is a quite method. I will definitely try that. Thanks again, Best regards, Saeid
