Sven Friedel
COMSOL Employee
10 years ago
3 feb 2015, 03:11 GMT-5
Hi Daniel,
1) you can define under definitions a coordinate system of your choice, eg. a cylindrical one.
2) You can write out coordinate data e.g. (sys2.r,sys2.phi,sys2.z) just as you would write out any data.
3) data will by default be exported within the mesh points, so you will get additionally (x,y,z) out which I don't think yopu can suppress
4) if you need your data e.g. on a cylindrical grid, you may want to defrine those points r(i), phi(i), z(i) in a data file and chose the export option "points to evaluate in" --> "from file".
This should bring you a step further to what you want to achieve - if not, let me know.
Sven
Hi Daniel,
Sven
10 years ago
9 feb 2015, 08:16 GMT-5
Thank you. Finally I used java to do the following:
- loop over a regular grid in my custom coordinate system
- using a 4x4 transformation matrix T (rotation+translation) I transform these points to the global CS
- write out the (x,y,z) coordinates of the points in the global CS into a file
- define this file as the set of points for evaluation, as you suggested in point 4)
- In order that the electric field (which is a vector quantity) be written out finally in my custom CS, I define 3 quantities to be exported: Rxx*Ex+Rxy*Ey+Rxz*Ez, Ryx*Ex+Ryy*Ey+Ryz*Ez, Rzx*Ex+Rzy*Ey+Rzz*Ez, where the R matrix is the rotational part (upper left 3x3 matrix) of the inverse of T
- The output file now contains the global (x,y,z) coordinates and the transformed E-field components, so I post-process this file and transform these global coordinates to the local ones using the inverse of the T matrix. I write out the transformed coordinates and the field components to my final fieldmap file.
This works.
This works.
