Frequency sweep - Help
Posted 30 mag 2010, 01:03 GMT-4 5 Replies
Hey guys,
My goal is to plot the dispersion diagram of a single-wire transmission line, aka sommerfeld wave (or goubau line).
1st try:
I used the 2D perpendicular hybrid wave application mode. I did mode analysis (see attached file if you like). According to the analytical solution and the expected field lines, I found the proper effective mode index (1.00something) at 1 GHz frequency.
My question : How can i sweep this frequency to get the dispersion curve?
My problem: If i use parametric solver instead of eigenmode solver it will not calculate the mode that i want.
I hope I get a response, thanks in advance!
Mil
1st try:
Mil
5 Replies Last Post 8 ago 2010, 14:31 GMT-4
