Parametric solver working on mesh sizes in Comsol 4
I want to do some mesh studies and I thought parametric solver can be a good option (mapped mesh). However it seems it is not forcing meshes to remesh before solution. Any ideas?
1 Reply Last Post 5 giu 2010, 05:51 GMT-4
Posted: 1 decade ago 5 giu 2010, 05:51 GMT-4
Its correct that in V3.5a there is an option for force the remesh. It must be in there too, probably hidden in another model tree level, Have you turned on the options to see advanced features.
But perhaps its not yet fully implemented, which astonishes me, they have at least one examplewhere you use the "h" parameter to remesh and analyse the results with respect to meshing denity set as a parameter. try to find back that example
Iavr
Hi Its correct that in V3.5a there is an option for force the remesh. It must be in there too, probably hidden in another model tree level, Have you turned on the options to see advanced features. But perhaps its not yet fully implemented, which astonishes me, they have at least one examplewhere you use the "h" parameter to remesh and analyse the results with respect to meshing denity set as a parameter. try to find back that example Good luck Iavr
