Henrik Sönnerlind
COMSOL Employee
10 years ago
6 mar 2015, 04:55 GMT-5
It seems to be essentially the same question as in
www.comsol.com/community/forums/general/thread/63221
The most straightforward way is to introduce Contact pairs between the layers.
Alternatively, you could use a Thin Elastic Layer with compression-only stiffness, but that may not converge well. In practice you would need some small stiffness in tension too, and a smooth transition.
Henirk
http://www.comsol.com/community/forums/general/thread/63221
Henirk
10 years ago
6 mar 2015, 06:00 GMT-5
Thanks Henrik for your quick answer and your suggestion. However, I tried to define contact pairs, but without success. There is no selectable boundary. Do you know a tutorial which explains how to introduce such a contact pair?
Maybe you want to have a look to my model. The contact pair has to be defined between the two lower rectangles.
Thanks a lot and best regards,
André
André
Henrik Sönnerlind
COMSOL Employee
10 years ago
6 mar 2015, 09:54 GMT-5
In order to use Contact, you must use Form Assembly at the end of the Geometry sequence, so that the domains are not 'glued' to each other.
For examples of contact modeling, go to Model Libraries (in the File menu, for example). Search for "contact", and look at the results under the Structural Mechanics folder.
A Thin Elastic Layer can be used both on an internal boundary and on an assembly.
Henrik
Henrik
10 years ago
6 mar 2015, 10:11 GMT-5
You are right. I found how to define Contact Pairs together with Form Assembly, but than the stress of the top layer will not effect the bottom layer. Therefore I will try Thin Elastic Layer.
