bouyancy effect
I found that with the multiphysics module using laminar flow and heat conduction in solids
on air in a closed cavity with temperature defined boundaries and gravity volume force I get
flow patterns. Does this simulate the bouyancy effect correctly?
From my experience, the heat transfer module (with conjugate heat transfer) is needed if you have a heat
source in the model plus a fluid flowing in
but in the above example the multiphysics model seems to be enough
thanks
David
1 Reply Last Post 8 mar 2015, 22:12 GMT-4
Posted: 10 years ago 8 mar 2015, 22:12 GMT-4
Hi:
for your question ,I suggest you look at the case.
Hi: for your question ,I suggest you look at the case.
