parametric sweep
HI,
I am working on Piezoresistivity, Boundary currents module and time dependent study. I have given a time dependent pressure load in the form of a square wave on a thin plate. Since I intend to find the response for a number of plates of different thickness, I have used the parametric sweep option. However, I am getting the following error.
" Error in sweep: The following feature has encountered a problem:
Constraint found for variables in different Segregated groups. Try to merge these groups.
- Feature: Time-Dependent Solver 1 (sol1/t1)"
Can someone help me out with this error?
Thank you in advance!
1 Reply Last Post 13 giu 2016, 12:37 GMT-4
Hello Bhargav Mistry
Posted: 9 years ago 13 giu 2016, 12:37 GMT-4
Had the same question
Facing error:
for electrostatically actuated canilever example.
Had the same question Facing error: Constraint found for variables in different Segregated groups. Try to merge these groups. - Feature: Time-Dependent Solver 1 (sol1/t1) for electrostatically actuated canilever example.
