Turbulent two-phase flow
Posted 9 mar 2015, 12:51 GMT-4 Computational Fluid Dynamics (CFD) 1 Reply
Hi all,
I am modelling a turbulent two-phase flow (phase-field) over a dike profile with different roughness sections. However I am having some troubles. Currently I am using an initial interface thickness of 0.07 metres. After approximately 4 seconds al the water dissapeared, which means there is loss of mass. When I decrease the thickness of the initial interface, and also decreasing the size of the mesh, I keep getting the error: 'non linear solver did not converge'. Besides this, the calculation time increases significantly when decreasing the mesh size and thickness of the initial interface.
Does anyone have a suggestion how I can change my model so it is capable to model the turbulent flow over the dike profile, with conservation of mass. I have to do a lot of simulations and therefore it is important that the calculation time will not become extremely large (days).
Thank you in advance.
With kind regards,
Anouk Bomers
With kind regards,
Anouk Bomers
1 Reply Last Post 11 mar 2015, 09:49 GMT-4
