Error in pressure drop simulation
Posted 11 mar 2015, 09:51 GMT-4 Fluid & Heat Version 5.0 1 Reply
Hi!
I get the following error when trying to simulate the pressure drop in a long pipe with a lot of inlets (se attached model).
Failed to find a solution.
Segregated group 1
Matrix has zero on diagonal for the SSOR update submatrix in the Vanka algorithm.
In segregated group 1:
The model has been working before but when i made a few changes it won't run anymore.
Thank you for your help!
Segregated group 1
1 Reply Last Post 12 mar 2015, 10:57 GMT-4
