viewing 2d plots
Posted 18 giu 2010, 07:15 GMT-4 Fluid & Heat, Results & Visualization 12 Replies
this seems to be a simple thing but i cant seem to figure it out. i have very high aspect geometry in my model so it helps to view it (in 2D) with the axes not being equal. this was simple in previous comsol versions. i can do it in 4.0 through changing the view settings under definitions, but then this view doesnt carry through to the 2d surface plot (even though the same view is specified in the 2d plot settings). is this a bug or am i missing something?
Adam
I'm not sure its implemented yet, I was also looking for it the other day, no success so far ;)
sorry for that cannot do better
Yes, in 4.1, go to Defintions>View>Axis in the Model branch (or the Axis subnode for another View if used) and clear the "Preserve aspect ratio" check box. Then update the plot (and possibly click the Zoom Extents button) to make the geometry fill the Graphics window.
Magnus Ringh, COMSOL
check the "view" node(s), & sub-node you have a few check boxes about scaling there
I'm having the same problem than Adam. My solution is very simple: concentration vs. time vs. length in a 3D plot built from the height expression of a surface 2D plot. I have several domains of a few micrometers and one domain of 5 millimeters. When I selected a dependent variable and its domain on COMSOL 3.5 it adjusted correctly de x-axis scale in order to display the results in a full 3D plot. But in COMSOL 4.1 I'm getting only lines, and so thin that they seem almost invisible. I've tried everything: zoom extents icon, deselect "preserve aspect ratio", deselect "lock axis"... and nothing works. I think it's a bug of the last version 4.1.0.185. Besides, I'm unable to find any way to choose the axis min/max representation in 3D plots. The axis subnode only appears in 1D and 2D view subnode.
Exists any way or workaround to fix it? Thanks in advance.
I have a "Range" tab in the "3D plot - Surface" sub-node where you can change scale and range. You can also link different styles in between plots
You have also "filtering" to select only some parts, domains or values, and you can also make a derived "Data Set" with only part or projections of the results
I'm not sure what you mean about correctly scaling the "x axis" ? in 1D line plots you have by default "arc length" as X-data, but you can change that too
Thanks for your help. I have a 2D plot built from a parametric extrusion of a 1D data set.
I'm solving a simple diffusion problem, so at first I have some 1D line plots of concentration vs. position. Each line belongs to a different time.Then, I build a parametric extrusion data set from the original solution data set and plot it on a 2D surface graph. Everything works well until then. But when I tell COMSOL to plot the height expression of the 2D surface in a new 3D graph I only obtain an ultra-thin line of a few micrometers thick because the x-scale is set to 5 mm (the total length of all domains) and that concentration only exists in a specific micrometric domain.
What can I do? Thanks very much in advance.
well bug reports must go to "support" as I cannot do much, I'm not even "COMSOL" but there is one trick in 2D view you need to refresh manually the plot (in the view window) AND then the rescale in the 2D plot window and in that order (if I remember right) It's what's called a feature ;)
I think v4.2 has a similar bug. I have a 16 x 5 aspect ratio, but when we go to export it as an image sequence or gif or flash, comsol (randomly?) places an image every so often which has aspect ratio 1:1 -- the picture itself keeps the same pixel ratio 1000 x 700 though. I've ticked the preserve aspect ratio and all that.
My "workaround" is to take advantage of the randomness and export several "identical" image sequences and then just merge the two taking only the 16 x 5 ones.
If someone else needs help, problem is fixed in the update 1
*Lock aspect ratio now works as expected also for image export.
Seems to be working well.
I am new to Comsol, and I am using comsol3.4, I have the same problem.
how can I change the scale of axis for the surface plots?
right now the surface 2d plot seems like line and I have ratio of (x to y) is 100:1.
Thanks in advance for your help.
Sepideh
