Why do I get "Error 9171"
Posted 21 giu 2010, 11:29 GMT-4 2 Replies
Is there an issue with using constants, defined in the Constants window, to define geometries?
I have defined a number of constants that I want to use as geometric parameters, but I get a syntax error when inputing the constant names into the geometry dimension fields:
Error: 9171
Syntax error in expression
- Expression: 50 [mm]
What is the cause of this?
Thank You,
Jonathan
Error: 9171
Thank You,
Jonathan
2 Replies Last Post 21 giu 2010, 16:30 GMT-4
