Instanteneous Jump of Temperature
Hi, COMSOL community.
I model the heating of solid (time dependent task). The heating is instaneous. I.e. heat spreads through the solid without any sources but in several (point-like) moments temperature jumps. The description of the heat source is possible only by these temperature jumps. The description by the common way - by the heat power density - is impossible due to physical limitations.
So, the scheme of the heating is:
1. Initial instanteneous temperature jump at t=0
2. Free heat spreading during the time from t=0 to t1
3. Instanteneous temperature jump at t=t1
4. Free heat spreading during the time from t=t1 to t2
and so on
So, the question is: how I can include temperature jumps into the model?
I could assume 2 possible ways:
- using separate steps (Step) for every time interval (0,t1), (t1,t2)
- or using several Heat Transfer in Solids Interfase (Physics) for every time interval (0,t1), (t1,t2)
where initial conditions for Step/Physics are results from previous Step/Physics.
If these are right assumptions, could anybody tell me the way to transfer the data from one Step/Physics to another?
Or, may be, there is any simple way?
2 Replies Last Post 17 dic 2015, 06:46 GMT-5
Posted: 10 years ago 26 mar 2015, 17:10 GMT-4
__Solved__
__Solved__
Posted: 9 years ago 17 dic 2015, 06:46 GMT-5
hi, Antonio
i have the same problem and i am wondering how did you solve this problem. would you please tell me how to solve it? And another problem is the jump of the dependent variable might bring some trouble with the convergence such as singularity, how could i avoid it?
hi, Antonio i have the same problem and i am wondering how did you solve this problem. would you please tell me how to solve it? And another problem is the jump of the dependent variable might bring some trouble with the convergence such as singularity, how could i avoid it?
