How can i perform a simulation on water vapor breathability of porous membranes?
Posted 7 apr 2015, 01:38 GMT-4 0 Replies
The membrane considered here varies in thickness.
On one side of the membrane, the environment (still air) is 35 degrees Celsius and has a saturated relative humidity, which translates into partial pressure of 5620Pa.
On the other side of the membrane, the environment is kept at 0% relative humidity with the help of a desiccator. (also 35 degrees Celsius)
I want to see if the varying membrane thickness would change the vapor transport rate through the membranes.
Any advice would be helpful,
Thank you
Hello Seongkyung Hong
