Include text files in comsol
Hello guys,
I would like to kkno if is possible introduce some data in Comsol.
For example, I have calculated therical values for voltage in a cell, but one of the equation that i need to use need other variable, the reals one.
The formula in one part is ( U - Uo ) where U are the real values, depending of the conecntration (but i have this values only in a text file), and Uo are the theritical values that depend of the concentration calculated with comsol.
There are posibilities to combine this values in dependency of the concentration (i'm usin convenction a diffusion equation)
Maybe not only the text files, but the data that I have
regards
Pablo
1 Reply Last Post 10 lug 2010, 14:51 GMT-4
Posted: 1 decade ago 10 lug 2010, 14:51 GMT-4
I believe you can solve your issue by loading the tesxt data into an interpolation function of COMSOL and then apply this function to your eqautions or data filed(s).
Check the doc on the "functions"
Hi I believe you can solve your issue by loading the tesxt data into an interpolation function of COMSOL and then apply this function to your eqautions or data filed(s). Check the doc on the "functions" Good luck Ivar
