Temperature at outlet for non-isothermal laminar flow in circular tube
I am examining a non-isothermal laminar flow in circular tube in COMSOL where the heat transfer fluid in the tube is heated as is passes the tube. Since the flow is laminar a velocity profile will form. This will impact the outlet temperature since the average temperature at the outlet won't be the actual outlet temperature, i.e. the heat transfer fluid in the middle will have twice the velocity of the average and hence the fluid with this temperature will exit in a greater extent.
How can I take the velocity profile and circular cross-section into account and get the "actual" outlet temperature?
Thank you!
4 Replies Last Post 3 mag 2015, 14:48 GMT-4
Frank van Gool COMSOL Employee
Posted: 10 years ago 28 apr 2015, 11:09 GMT-4
Dear Fanny,
you can take the integral of the velocity times the temperature (w*T). Where you use the checkbox "compute surface integral".
This value should then be divided by the integal of the velocity only (total flux).
Frank
Dear Fanny, you can take the integral of the velocity times the temperature (w*T). Where you use the checkbox "compute surface integral". This value should then be divided by the integal of the velocity only (total flux). Best regards, Frank
Posted: 10 years ago 28 apr 2015, 11:19 GMT-4
Shouldn't this be additionally weighted by the local mass density?
Posted: 10 years ago 3 mag 2015, 14:47 GMT-4
Thank you! Though, I do not quite understand what you mean by "total flux" do you refer to the normal inlet velocity or something else?
Posted: 10 years ago 3 mag 2015, 14:48 GMT-4
Yup, though the density does not vary too much so I will disregard this.
[QUOTE] Shouldn't this be additionally weighted by the local mass density? [/QUOTE] Yup, though the density does not vary too much so I will disregard this.
