why do we have to add a dynamic viscosity to a type of solid material
Hi. When I add a solid material, it reminds me to add a dynamic viscosity to the material. It makes me feel confused as I think that a solid material does not have such a property .
Can someone help me solve this problem?
Thank you.
4 Replies Last Post 4 giu 2017, 17:26 GMT-4
Hello Min Liu
Posted: 10 years ago 11 set 2015, 11:05 GMT-4
same problem here...for aluminium selection, i was forced to give a value to dynamic viscosity...dont know what to do
Posted: 10 years ago 11 set 2015, 11:08 GMT-4
same problem here :(
Posted: 10 years ago 11 set 2015, 11:23 GMT-4
Make sure to turn off the fluid flow physics in the domain where you don't want it solved.
Make sure to turn off the fluid flow physics in the domain where you don't want it solved. Jeff
Posted: 8 years ago 4 giu 2017, 17:26 GMT-4
While I am doing the simulation of a fingertip which is touching a flat surface and when it is moving, so you mean I need to add the dynamic viscosity of the skin so that I will have a feeling how the skin is connected to the surface when it is moving?
