A basic formula change
I use COMSOL Multiphysics 3.5 Heat Transfer, Convection and Conduction, Steady-States Analysis to describe the temperature gradient around a thin wire. I want to change the standard formula used in COMSOL with other one that is using in this case. How can I do it?
Thanks in advance!
Mitko
2 Replies Last Post 15 set 2009, 03:13 GMT-4
Posted: 2 decades ago 15 set 2009, 01:17 GMT-4
To do so, you can go to physics -> Equation Systems, and then choose subdomain, boundary, or point (depending on what you want to do). In there you will find all the relevant equations. You can modify any of these.
Hope this helps.
To do so, you can go to physics -> Equation Systems, and then choose subdomain, boundary, or point (depending on what you want to do). In there you will find all the relevant equations. You can modify any of these. Hope this helps.
Posted: 2 decades ago 15 set 2009, 03:13 GMT-4
Thank you very much, Mario!
