22 lug 2010, 03:24 GMT-4
I believe its only through Matlab that you can get access to all the internals as long lists
22 lug 2010, 23:08 GMT-4
Dear Ivar,
Thanks for reply. Is it possible to use the geometry of Matlab in COMSOL?
With regards
ricky
Dear Ivar,
With regards
ricky
23 lug 2010, 03:52 GMT-4
The Geometry of COMSOL must be made up in the COMSOL internal geometry data-base file format, for this you should use the COMSOL matlab function calls, one way to start learing them is to generate your geometry once in COMSOL and then save the file asa "m" file and study that. Do not forget to read the doc.
In V4 everything (matlab calls too) has drastically changed (but the possibilities have also been drastically enhanced) so you should consider which version to use
25 lug 2010, 18:41 GMT-4
Thank you very much.
ricky
ricky
