heat transfer module-->fluid thermal interaction-->Turbulent non isothermal flow kw.
I´m trying to simulate a cold plate with some heat generation on the top of it. (that is transferred to the cold plate) I´m using the module:
My problem is that when I try to run the model I have this error:
Segregated group X3
Failed to evaluate variable.
- Variable: qwf_htgh
- Geometry: 1
- Boundaries: 558,559,560,561,562,563,564,565,566,567, ...
- Variable: q0_htgh2
- Defined as: (-qwf_htgh)
- Expression: d(((dVolbnd_htgh2*q0_htgh2*test(Ts))-(0))*(dvol),{test@0})
If somebody knows why this error shows up, please let me know. Thanks in advance!
A. Jenkins
0 Replies Last Post 22 lug 2010, 08:00 GMT-4
Hello Izaro LL
