Contact problem. Spontaneous rupture via friction. Stick-slip model.
Posted 20 mag 2015, 07:21 GMT-4 Structural Mechanics 1 Reply
I'm trying to model a spontaneous rupture at a ground fault via friction. Before to do this, I tried some simple tests.
In particular, I tried to model a block sliding on a flat rigid surface, with contact friction and gravity using a time dependent study. I applied to this block a force, progressively increased in time. The friction follows the classical Coulomb law (only coulomb coefficient miu). I imposed various values of miu. I should observe a stick regime until the friction force is overcome by the applied force and, then, the slip regime should start. Instead, I observe that the block slides always, even when the force is very small and miu is very high. I didn't observe difference using different value of miu. I used also the Comsol test case “sliding wedge” but I was not able to see a stick-slip regime. Could you suggest me a solution? Perhaps, is not possible to model the stick-slip regime? I saw also the Comsol test case "contacting_rings" but I didn't find an error in my simple model.
Moreover, I noticed that Comsol accepts all value of miu, also unrealistic (much more of 1). Why?
Many thanks
Many thanks
1 Reply Last Post 22 mag 2015, 02:17 GMT-4
