Laser Transmission Welding / Overshooting? -> Lumped Mass Matrix
Posted 26 lug 2010, 13:59 GMT-4 Heat Transfer & Phase Change, Materials, Studies & Solvers Version 4.0a 4 Replies
Hello everybody,
currently I'm working on a simulation of the laser transmission welding process. In this process a laser beam passes through a transmitting part and heats up an absorbing part which then starts to melt. Due to heat conduction this in turn heats up the transmitting part and a welding seam occurs.
I only simulate temperature profiles via the general heat transfer module (transient) , no mechanical behaviour is regarded.
My problem is the following:
I'm constantly getting negative temperatures near the welding zone. When I highly increase the mesh density in this area, this effect can be weakened but the computional time increases - of course - a lot.
I think this effect can be due to the steep increase of the absorption coefficient at the interface of the two joining partners. Somebody told me that this leads to overshooting/undershooting in the welding zone and this effect could be weakened by using a lumped mass matrix.
So my question is:
Can I tell COMSOL to use a lumped mass matrix in its calculations? If yes, how?
Thank you very much,
Anita
P.S.: Any other solutions for this problem are VERY welcome, too :-)
So my question is:
Anita
4 Replies Last Post 10 gen 2011, 09:31 GMT-5
