9 years ago
22 mag 2015, 04:41 GMT-4
Hallo,
Have you tried the moving mesh physics (ALE)?
In case you haven't, I believe the solution for a CLOSED system should look something like this:
1. Define the piecewise function (pw1) of the movement using the displacement as a factor.
2. Add the Ale physics in which you define the movement of the anode by a "Prescribed deformation". For an input, for example in the x-direction, use the time operator t as an input for the piecewise function describing the movement of the anode (something like: pw1[t]).
3. Define a "Free deformation" on surrounding domain of the model.
4. Add "Prescribed mesh displacement" surrounding the anode boundaries with the same input as in point (2).
5. Use a fine mesh setting and in the time-dependent solver, check the "automatic meshing" option.
if solver convergence was not achieved, you might need to refine the mesh or play a bit with the solver, especially the time stepping type of the stop condition for re-meshing.
I hope that helped you a bit.
Good luck,
Zedd
Hallo,
Good luck,
Zedd
9 years ago
23 mag 2015, 01:49 GMT-4
Hello
Many thanks for your replying, and I am very sorry so late reply to you !
I have tried the advice that you offered several times , and the Ale physics is not working .
But this i s a question that's always puzzled me .
Would you leave me your email? I
If it's convenient for you, I will send the model to you so that you can find the solution .
I am really grateful.
Thanks again!
Hello
Thanks again!
9 years ago
26 mag 2015, 10:48 GMT-4
Hallo,
Let's keep the discussion in this post alive so that other COMSOL users find it useful. Nonetheless, upload a simplified version of your model and i will be happy to take a look at it.
Moving mesh physics is not hard to apply, yet sometimes tricky. I attached a simple model for the moving mesh. Maybe it could provide a starting point for your model.
Have fun,
Zaid
Hallo,
Have fun,
Zaid
