hi
hi
i'm trying to use comsol for wind turbine , how can i make the blade moving in the air tunnel by the wind force
cheers
2 Replies Last Post 11 ago 2010, 09:08 GMT-4
Posted: 1 decade ago 11 ago 2010, 09:07 GMT-4
Hi MOHAMED,
Regarding wind turbine application the generator should have a minimal
reluctance torque and require to be direct-driven to lessen mechanical losses in the application.
For this objective the stator winding is wound around a slotless ring core. The rotor disc has
18 surface installed magnet poles.
Jessica Leahy
CollectWealth.ws
Hi MOHAMED, Regarding wind turbine application the generator should have a minimal reluctance torque and require to be direct-driven to lessen mechanical losses in the application. For this objective the stator winding is wound around a slotless ring core. The rotor disc has 18 surface installed magnet poles. -- Jessica Leahy http://CollectWealth.ws
Posted: 1 decade ago 11 ago 2010, 09:08 GMT-4
Hi MOHAMED,
Jessica Leahy
CollectWealth.ws
