Importing PCB into COMSOL
Hello
I am trying to import a PCB file into COMSOL. I have the file in .pcb format, but I can generate the PCB in the odb++ format. COMSOL requires the new odb++(X) format. Does anybody know of a way that I can create a odb++(X) file from a odb++ file or from a pcb file? Or any other method that I can use to import my PCB into COMSOL?
4 Replies Last Post 22 set 2009, 03:45 GMT-4
Posted: 2 decades ago 19 set 2009, 05:58 GMT-4
I know that COMSOL supports DXF import, but I dont think that this method provides any track width information.
Tom
Hi, I know that COMSOL supports DXF import, but I dont think that this method provides any track width information. Regards, Tom
Posted: 2 decades ago 19 set 2009, 09:41 GMT-4
I use the GDS from the "import ECAD" option, this works (mostly)
Hi I use the GDS from the "import ECAD" option, this works (mostly) Good luck Ivar
Posted: 2 decades ago 21 set 2009, 10:07 GMT-4
I've tried several simple test pcbs in ODB++(X), with almost no success at all. There is an article in the multiphysics blog to come (at least it was announced in the "Working with CAD" posting), and I am looking forward to that.
Best regards
Matthias
Hi, I've tried several simple test pcbs in ODB++(X), with almost no success at all. There is an article in the multiphysics blog to come (at least it was announced in the "Working with CAD" posting), and I am looking forward to that. Best regards Matthias
Posted: 2 decades ago 22 set 2009, 03:45 GMT-4
I found a program that can convert gerber files to .gds. The problem is that it only works if I import the metal frame(does not work for whole 3D model). I think the problem is that there are so many different file formats that PCBs are saved in.
