Cube in a cube
hI
I'm trying to solve the problem of having a cube silicon in a cube of air.
One side of the silicon has 5Volts on it.
I chose electric current from the physics menu and assigned electric potential by right clicking on the electric current physics category.
The cube of air has 0.5m sides, the silicon has 0.1m sides.
It seems like a really simple problem but I keep getting the error messsage saying that it is a 'singular matrix'
I tried lowering the tolerance from union, from 10^-6 to 10^-15.
Also tried changing the mesh size from extremely fine to coarse.
Any help would be appeciated.
4 Replies Last Post 4 ago 2010, 15:24 GMT-4
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 4 ago 2010, 02:21 GMT-4
The problem is in the material properties for the air domain: the elecrtic conductivity is identically 0. Changing it to a very small but nonzero number should make it possible to solve the problem quickly.
Magnus Ringh
COMSOL
Hi, The problem is in the material properties for the air domain: the elecrtic conductivity is identically 0. Changing it to a very small but nonzero number should make it possible to solve the problem quickly. Best regards, Magnus Ringh COMSOL
Posted: 1 decade ago 4 ago 2010, 03:07 GMT-4
hi
well magnus was faster than me ;)
I would also suggest to define a gnd potential somewhere, it makes more sens
so current ec means conductivity <> 0 too
hi well magnus was faster than me ;) I would also suggest to define a gnd potential somewhere, it makes more sens so current ec means conductivity 0 too -- Good luck Ivar
Posted: 1 decade ago 4 ago 2010, 15:24 GMT-4
Thank you very much everyone.
Thank you very much.
