4 ago 2010, 10:38 GMT-4
Hi, I have a fsi model, however, I also need to add another fluid to the model. So I would have the solid with a layer of fluid 1 surrounding it and then fluid 2 comes in contact with fluid and the structure. I do not know how to add that extra fluid in there, is there a specific module that deals with fluid-fluid interaction.
Thank you, I hope this is clear.
Marina
Then I guess you should use Level-set or two-phase flow model to track the boundaries between the fluids. There is a great example in Comsol 3.5a (but not 4), but I don't know where exactly.
Edit: It is called "Two Phase Fluid-Structure Interaction", but I don't have MEMS to check exactly.
[QUOTE]
Marina
[/QUOTE]
4 ago 2010, 11:06 GMT-4
Thank you so much. I actually have version 3.3, I know that 3.5 has that capability, but 3.3 doesnt, I was just trying to figure out if there is another way to do it, so I would not have purchase the new version. Do you know of any other way of doing it?
4 ago 2010, 12:09 GMT-4
If you mean MEMS, you don't need MEMS for this. You need Chemical Engineering Module for two-phase and level-set methods I guess. But, I don't know of any other method to have F-F, except these two in Comsol.
[QUOTE]
[/QUOTE]
