mesh dependency of "heat sink with fins"?
Posted 10 giu 2015, 12:11 GMT-4 Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Mesh Version 5.1 0 Replies
I just run the demonstration application (heat transfer) "heat sink with fins" with the preset mesh without any changes. Then I added a second mesh where I had a one step less coarse mesh.
I compared the cooling power and the result was only 90 % of the solution with the coarser mesh (5.2374 W vs. 5.7559 W.
What did I do wrong? Is the preset mesh not fine enough?
I tried that, because I had problems with solutions beiing dependend of my mesh. I simulated a simple air flow over a heated plate and wanted to know the heat loss of the plate.
Thank you for any hint!
Hello Lotta Koch
