Fluid Flow through a Loop Reactor
Joao Carlos Silva Lira
Hello everyone,
I just started using Comsol for a few weeks.
Currently, I am trying to simulate fluid flow through a Loop Reactor that I designed in inventor.
Then, since I imported it to Comsol, I used cap faces to build the mesh for the volume. However, I want to define some conditions inside the reactor, basically I want to increase the velocity inside the loop (for example, using a pump) having low flow rates for inlet and outlet.
Is it possible to create another condition to change the velocity instead of only inlet and outlet?
Thank you for your help
0 Replies Last Post 16 giu 2015, 18:28 GMT-4
Hello Joao Carlos Silva Lira
