Magnetic Field of a Multi Layer solenoid
Posted 18 giu 2015, 14:19 GMT-4 Low-Frequency Electromagnetics, Interfacing, Materials, Mesh, Results & Visualization, Studies & Solvers Version 5.0 5 Replies
Hello Everyone,
I have no experience in using COMSOl.
My professor wants me to run an example project in this software and I have a few specific questions.
The problem statement is:
I have a multi layer coil. Each layer has 10 wounds and there are 5 layers. The coil is wound on a ceramic rod. I need to give AC current as an input and plot the magnetic field distribution around the coil. ( more importantly along the axis of the rod).
How I proceeded
I designed the coil in SOLIDWORKS and imported the file into COMSOL. I designed an cubical test area around the coil (infinite element domain). I specified material for coil as copper and for the test area as air.
What should be the selection in Ampere's law?
I included coil ends and the sidesof test area cube in magnetic insulation.
Then I chose Single turn coil and gave boundary feed (How can I input AC current?) to one end and ground to another.
I chose a fine mesh size and meshed the coil using free tetrahedral. For the test area I chose free triangular.
I input 10 kHz as the frequency.
I don't see any fancy plots coming up. All it shows is 0 and faint green
Can someone tell me where I am going wrong? How do I proceed further?
Thanks in advance,
Rahul Korpu
How I proceeded
Thanks in advance,
Rahul Korpu
5 Replies Last Post 23 ago 2015, 15:37 GMT-4
