How to stop a runaway simulation?
I am running simulations automated with matlab scripting. Sometimes the simulations run away (do not converge) and last for ever with a extremly small time step. In such situations one usually hits the stop button in the solution progress window, but in an automated run you can't.
I guess it could be done with the Stop Condition in the 'Solvers Parameters - Time Stepping - Use Stop Condition' field.
There I could use the current or last time step size and set a limit to it.
But how can I access the current (or last) Stepsize ? Is there a variable I can use?
Thanks for any ideas,
Martin
7 Replies Last Post 30 nov 2012, 06:32 GMT-5
Hello Martin Suter
Posted: 1 decade ago 20 giu 2011, 09:04 GMT-4
Did you find an answer for this issue? I have exactly the same problem.
Posted: 1 decade ago 20 set 2011, 13:27 GMT-4
Same Problem...
Could someone give an answer?
Same Problem... Could someone give an answer?
Posted: 1 decade ago 21 set 2011, 02:57 GMT-4
No solution so far ...
Posted: 1 decade ago 21 set 2011, 03:44 GMT-4
Manualy:
ctrl + pause/break
Using script - check the documentation of a function that you use... Try to find where "the evaluation of convergance" is calculated and write proper condition..
Rafał Piotuch
Manualy: ctrl + pause/break Using script - check the documentation of a function that you use... Try to find where "the evaluation of convergance" is calculated and write proper condition.. Best regards, Rafał Piotuch
Posted: 1 decade ago 22 set 2011, 10:37 GMT-4
Dear Rafal Piotuch,
I don't quiet see what you mean!
Could you please be more precise?
Cheers
Dear Rafal Piotuch, I don't quiet see what you mean! Could you please be more precise? Cheers
Posted: 1 decade ago 23 set 2011, 01:16 GMT-4
Dear Julien Egger;
sure:) Hope you use Matlab to solve problem, else I don't know how to help you:)
So.. If you use Matlab it is easy to stop simulation manualy- just press ctr+pause/break and the simulation stops after some time - but for sure you want to stop simulation automaticly, without any human control...
When you solve sth. using for example femtime function.. read documentation of such function and read script of this function - there must be a "place" in code that refers to convergance calculation... So there must be a variable that stores current step_size.. If you will write in pseudo code:
if (step_size<0.0001) then
%the function return sth, so it should be stopped or proper value should be returned.
return(0);
it should be working.
So that's all.
Rafał Piotuch
Dear Julien Egger; sure:) Hope you use Matlab to solve problem, else I don't know how to help you:) So.. If you use Matlab it is easy to stop simulation manualy- just press ctr+pause/break and the simulation stops after some time - but for sure you want to stop simulation automaticly, without any human control... When you solve sth. using for example femtime function.. read documentation of such function and read script of this function - there must be a "place" in code that refers to convergance calculation... So there must be a variable that stores current step_size.. If you will write in pseudo code: if (step_size
Posted: 1 decade ago 30 nov 2012, 06:32 GMT-5
look up the global variable "timestep" in the comsol documentation. It does exactly what you want :)
