Memory error
I am getting the following error:
Failed to find a solution.
Unable to read or write out-of-core file.
I am using an extra fine mesh, because I am modelling the stresses in microwells in a PDMS strip, and with a courser mesh the wells aren't defined.
Thanks.
2 Replies Last Post 29 ott 2015, 05:03 GMT-4
Hello Valerie Bentivegna
Posted: 9 years ago 28 ott 2015, 09:40 GMT-4
Hi~!
this problem happens to me recently. I think, maybe it is the reason that the virtual memory is exhausted while calculation. Try to set virtual memory to a bigger disk and make it larger.
I am going to try this way, hoping I am lucky~~
Best regards
Xiaoqiu HE
Hi~! this problem happens to me recently. I think, maybe it is the reason that the virtual memory is exhausted while calculation. Try to set virtual memory to a bigger disk and make it larger. I am going to try this way, hoping I am lucky~~ Best regards Xiaoqiu HE
Posted: 9 years ago 29 ott 2015, 05:03 GMT-4
Hi~!
Now I am totally sure that this problem is caused by the exhaustion of windows' virtual memory. Set window's virtual memory to a disk which has a large free space and re-run the model, then you would not meet that problem again.
Best regards
Xiaoqiu HE
Hi~! Now I am totally sure that this problem is caused by the exhaustion of windows' virtual memory. Set window's virtual memory to a disk which has a large free space and re-run the model, then you would not meet that problem again. Best regards Xiaoqiu HE
