Conjugate Heat Transfer , Thermal Tank SIM
Posted 10 lug 2015, 05:33 GMT-4 Heat Transfer & Phase Change Version 4.4 0 Replies
i have an issue with my project in Comsol 4.4.
I want to simulate a basic loading process of a thermal Tank with heat isolation. So im using the CTH-physic model. My issue is that im feeling the constant pressure point configuration is not right. After one hour, the loading behavier( i mean the thermal layer behavier) is weird. I dont know what is wrong the in project. Could anyone a have look at the project?
The Nodes im using are (because the project is in german):
Laminar Flow
-Inlet 1
-Outlet 1
Heat Transfer
-Inflow Heat Flux
-Outflow
-Convective Heat Flux ( on the walls of the isolation)
-Volume Force
-Constant Pressure Point ( on one edge of the ground of the water zylinder)
I would really appreciate any suggestion.
Hello Olef Warschofski
