Getting scattered field from magnetic current
i'm trying to figure to out how to get the scattered field from a magnetic current excitation.
The model is 2D, I have a arbitrary object. Then I assign a point to be magnetic current excitation. The magnetic current generates spherical wave with TM polarization. Is there a way to get the scattered field instead of the full field? or the only option i have is the define this spherical TM wave as the background field?
1 Reply Last Post 17 lug 2015, 13:37 GMT-4
Posted: 10 years ago 17 lug 2015, 13:37 GMT-4
I believe that the scattered field formulation requires that you define a background field. That said, assuming linearity, you can see the scattered field with the full field formulation by subtracting the spherical wave.
