Incremental inductance for coil
Hello
I have a 2d axisymmetric air core inductor. I want to check the incremental inductance, i.e. the inductance change vs DC-load current. An AC current source is superimposed to simulate ripple current.
So in my model I need a variable DC current source and a constant AC current source to be flowing in the coils. Is this possible in COMSOL? If so, how should I proceed? Any suggestions? Electrical circuits module?
Thank you for reading
Valdemar
1 Reply Last Post 23 lug 2015, 02:22 GMT-4
Posted: 10 years ago 23 lug 2015, 02:22 GMT-4
I suggest that you take a closer look to the chapter describing the harmonic perturbations, i.e. ACDCModuleUsersGuide.pdf page 192 ++
And then check the Model/Application Library for examples there too
Hi I suggest that you take a closer look to the chapter describing the harmonic perturbations, i.e. ACDCModuleUsersGuide.pdf page 192 ++ And then check the Model/Application Library for examples there too -- Good luck Ivar
