Mesh size component
Hi All,
I am wondering if there is a way to find max and min mesh size in the direction of x, y and z axis? I need it to compare my model with a published paper. I understand h is the variable for mesh size, but it does not have component in a specific direction.
2 Replies Last Post 24 ago 2015, 05:46 GMT-4
Posted: 9 years ago 23 ago 2015, 23:21 GMT-4
I end up export the mesh and calculate element size by Matlab. =]
Posted: 9 years ago 24 ago 2015, 05:46 GMT-4
I find your arguments interesting and that you should push them to "support" that feature might appear in a future release
But have you tried to select an Edge and asked for the Derived Values of "min", "max" and "average" over the edge of the value of "h" ? this should give you a good clue valid OK only along the line
Hi I find your arguments interesting and that you should push them to "support" that feature might appear in a future release But have you tried to select an Edge and asked for the Derived Values of "min", "max" and "average" over the edge of the value of "h" ? this should give you a good clue valid OK only along the line -- Good luck Ivar
