Electrical Circuit & Spice Netlist in COMSOL 4.0
I have a problem with coupling a model (copper wire) with two terminals to electrical circuit (e.g. current source) in COMSOL 4.0.
I've done it before in COMSOL 3.5 by using a spice netlist and defining two circuit terminal for two ends of the wire which it works, but I need to apply different currents with phase difference to a multi wires model, so I use COMSOL 4.0 which the phase is supported for a current source.
Two terminals are added for two surface boundaries in model (with terminal names: A and B). I use Electrical Circuit in model and add a current source (sin) with nodes 1 and 0, but I don't know how to couple the source to two terminals (A and B).
I imported the netlist of the circuit used in COMSOL 3.5 here, but it doesn't work.
Thanks for any help
1 Reply Last Post 5 dic 2014, 01:59 GMT-5
Hello Sara Feb.
Posted: 1 decade ago 5 dic 2014, 01:59 GMT-5
I met the same problem with u. did you solve it?
