Plotting over a circle....
Hello everyone, I would like to ask how to plot data over a circle like cutline is used to plot data over a line while cutpoint over a point similarly how can one plot over a circle. I used trigonometric functions to form circle by using cutpoint but the graph plot is not ok...
5 Replies Last Post 14 set 2015, 22:01 GMT-4
Posted: 9 years ago 14 set 2015, 02:07 GMT-4
This sounds like a job for the Parametric Curve 2D data set.
Posted: 9 years ago 14 set 2015, 02:26 GMT-4
Thanks for the reply Gunnar. I used the parametric curve 2D but what expressions should i write in the x and y to have a circle. I used the expression r*cos(range(0,0.01,2*pi)) and r*sin(range(0,0.01,2*pi)) for the x and y but the range function does not work it is giving the message of unknown function or operator range.....
Thankssss
Thanks for the reply Gunnar. I used the parametric curve 2D but what expressions should i write in the x and y to have a circle. I used the expression r*cos(range(0,0.01,2*pi)) and r*sin(range(0,0.01,2*pi)) for the x and y but the range function does not work it is giving the message of unknown function or operator range..... Thankssss
Posted: 9 years ago 14 set 2015, 02:31 GMT-4
The x and y fields expect expressions defined in terms of a parameter. Try the following:
Minimum: 0
Maximum: 2*pi
x: r*cos(s)
y: r*sin(s)
[QUOTE] Thanks for the reply Gunnar. I used the parametric curve 2D but what expressions should i write in the x and y to have a circle. I used the expression r*cos(range(0,0.01,2*pi)) and r*sin(range(0,0.01,2*pi)) for the x and y but the range function does not work it is giving the message of unknown function or operator range..... [/QUOTE] The x and y fields expect expressions defined in terms of a parameter. Try the following: Name: s Minimum: 0 Maximum: 2*pi x: r*cos(s) y: r*sin(s)
Posted: 9 years ago 14 set 2015, 21:58 GMT-4
Thanks i got your point. I tried but it is giving the message
Cannot evaluate the expression
Failed to evaluate variable.
- Variable: s
- Geometry: 1
- Boundary: 1 2 4 5 7 8 9 15 53 54 67 77 79 98 99
- Expression: cos(s)
- Plot: previewplot1 (Line)
Thanks i got your point. I tried but it is giving the message Cannot evaluate the expression Failed to evaluate variable. - Variable: s - Geometry: 1 - Boundary: 1 2 4 5 7 8 9 15 53 54 67 77 79 98 99 Failed to evaluate expression. - Expression: cos(s) - Plot: previewplot1 (Line)
Posted: 9 years ago 14 set 2015, 22:01 GMT-4
thanks it worked.... thanks alot for the information....
