Enthalpy method in COMSOL
Hi, Can someone tell me what is the difference when we model a heat transfer problem using enthalpy method or Effective heat capacity method for Phase change problems...
2 Replies Last Post 11 feb 2016, 00:39 GMT-5
Posted: 1 decade ago 6 set 2010, 11:06 GMT-4
you can either provide the effective heat capacity, that is the heat capacity as a function of temperature or you can provide the enthalpy of the phase transition and apply it together with a distribution function that defines over which temperature range the enthalpy change is taking place.
It depends on the data you have available.
Regards
Edgar
Hi, you can either provide the effective heat capacity, that is the heat capacity as a function of temperature or you can provide the enthalpy of the phase transition and apply it together with a distribution function that defines over which temperature range the enthalpy change is taking place. It depends on the data you have available. Regards Edgar
Posted: 9 years ago 11 feb 2016, 00:39 GMT-5
dear
you told depending upon the data available
data means what??
dear you told depending upon the data available data means what??
