how to save mesh file in comsol
I want to save mesh and element
Initially I tried to use get and flsave but seems not working. Can someone explain.
Regards
1 Reply Last Post 7 set 2010, 02:52 GMT-4
Posted: 1 decade ago 7 set 2010, 02:52 GMT-4
meshes are stored in COMSOL as node , lines and volumes, i.e. geometrical entities and indexes to these items, this you can save in a few formats, see your doc or do a serach for "file formats" on the main COMSL web site
Elements are mainy definitions, and not saved as a "dec card" as for many other FEM software. You need to study the doc how to extract the index tables to identify which tape of elements are linked to which mesh entity, somewhat to lengthy to explain here. Start with a simple rectangle and 4-6 elements, and check the doc, then the model is simple enough to be understood by "hand"
Hi meshes are stored in COMSOL as node , lines and volumes, i.e. geometrical entities and indexes to these items, this you can save in a few formats, see your doc or do a serach for "file formats" on the main COMSL web site Elements are mainy definitions, and not saved as a "dec card" as for many other FEM software. You need to study the doc how to extract the index tables to identify which tape of elements are linked to which mesh entity, somewhat to lengthy to explain here. Start with a simple rectangle and 4-6 elements, and check the doc, then the model is simple enough to be understood by "hand" -- Good luck Ivar
