Setting If statement in COMSOL ODE
Hi, I am trying to solve an ODE in COMSOL (time-dependent) but i want the ode to be initiated only if the temperature is below certain value, say 272K. Is it possible to implement this in comsol?
4 Replies Last Post 7 ott 2015, 04:50 GMT-4
Walter Frei COMSOL Employee
Posted: 9 years ago 6 ott 2015, 09:23 GMT-4
You may want to look at this material, it may point you towards an alternative approach to what you are attempting:
www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/
www.comsol.com/blogs/using-the-previous-solution-operator-in-transient-modeling/
www.comsol.com/blogs/tracking-material-damage-with-the-previous-solution-operator/
Hello, You may want to look at this material, it may point you towards an alternative approach to what you are attempting: http://www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/ http://www.comsol.com/blogs/using-the-previous-solution-operator-in-transient-modeling/ http://www.comsol.com/blogs/tracking-material-damage-with-the-previous-solution-operator/
Posted: 9 years ago 6 ott 2015, 09:45 GMT-4
Alright thanks :)
Alright thanks :)
Posted: 9 years ago 7 ott 2015, 00:49 GMT-4
If I want to apply a specific ODE in the region with temperature < 272K, like du/dt = F, but in other region where T>272, I wish to implement another ODE, du/dt=0. This means that depending on the temperature in that particular region, the ODE will switch. Can this be done in comsol?
If I want to apply a specific ODE in the region with temperature < 272K, like du/dt = F, but in other region where T>272, I wish to implement another ODE, du/dt=0. This means that depending on the temperature in that particular region, the ODE will switch. Can this be done in comsol? Thanks
Posted: 9 years ago 7 ott 2015, 04:50 GMT-4
Use the following expression in the Source Term in the Distributed ODE node: ut-if(T<272,F,0)
